TechArt Wing Mounting help
Hi,
I bought a used TechArt Type IV wing that didn't come with mounting hardware. Reading some posts I thought the original screws would work, but it turns out they're too short. Has anyone installed this and can offer some advice please.
I will attempt to contact TechArt again. I'm tempted to just go to Home Depot and match the screw width but unsure if there is a special hardware mounting kit available.
Thanks!
Thanks!
Picture? Not sure how longer bolts are going to help unless the spoiler it self is narrower from mounting point to mounting point. Maybe measure? If that is all it is then yes some longer bolts and some stainless washers to fill the gap should do the trick. Cheers and good luck
