997.2 Battery Missing Something?
Old Mar 4, 2016 | 11:44 PM
StormRune's Avatar
StormRune
Just a small safety measure to add: And always disconnect the negative first. If you accidentally short the wrench or yourself to ground nothing bad happens. Then disconnect the positive while you cannot create a short (unless you touch the negative terminal directly). Doing the other way around can more easily result in a short to ground.
Old Mar 10, 2016 | 01:20 AM
docdrs's Avatar
docdrs
Just replaced my battery in my 997.2 I used an interstate 94R/H7 it was a breeze. Left the trickle charger in the passenger well socket so the car was nnever without volts
