Steering Leak
Steering Leak
Hi All,
2007 C4S RHD
Quick question - just came in from swapping pads and giving the car a check & came across a leak. Check out the attached (probably supersized photo, apologies). The brass fitting is leaking at the top where it joins to the plastic tube.
From the LHD PET (all I can find ATM) I'm pretty certain this is a leaky steering line.
Assuming that's correct - has anyone dealt with similar? Is there an o-ring, or just a compression fitting?
2007 C4S RHD
