Over Revs - Help
In my mind there are three things to be concerned about wrt over revs:
1) Was the last range 4/5/6 over rev less than 100 op hours ago?
2) Does the data bother you?
3) Do you plan to sell the car soon?
If the answer to any of these questions is yes... find another car. If your answers were no, no, and no then I suggest you use the over rev data to negotiate the price down.
In my mind there are three things to be concerned about wrt over revs: 1) Was the last range 4/5/6 over rev less than 100 op hours ago? 2) Does the data bother you? 3) Do you plan to sell the car soon? If the answer to any of these questions is yes... find another car. If your answers were no, no, and no then I suggest you use the over rev data to negotiate the price down.
50 hours, not 100
And buy a power train warranty
Regarding the questions:
1) Need to find out how long ago the over revs were...
2) No it does not bother me per say, but I am concerned this is due to my ignorance
3) No I don't plan on selling soon
I will ask the seller about it.
The rationale here is that if there has been no CEL or other complication within 40 operating hours of an "incident", ie over rev, it is commonly held that no damage has occurred to motor. Having regurgitated that tidbit it must be said that folks have posted cleaner scans than the one you are looking at. The owner will most likely deny knowing anything about what happened. Check the time stamp on the report yourself.
That's possible and a good point, however, I would think that even with the ECU tweaked to exceed the factory rev limiter any over revs limited by the rev limiter would be in range 1 or 2. It would still take a money shift to produce 4 to 6 range over revs.
