Sampling for Oil
I did an oil change a couple weeks ago after ~4600 miles, and got the results back from Blackstone (See attachment). Looks pretty good.
I'd like to take some more samples over time, to see how long I can go without doing an an oil change. What's the best way to sample the oil without actually changing the oil?
Can I use a pump through the filler tube or filter housing?
Thanks!
Thanks!
Oil is cheap, time is precious.
Also, I'm kind of curious to see how a serial analysis will do., i.e., 2000, 4000, 6000 miles (I'm a scientist, love data).
On any other car, would be simple enough to stick a vacuum pump hose through the filler hole and suck up some oil. On the Porsche, I wonder if it will break some unobtainium piece if I do it, or don't do it properly
I'm doing this sort of analysis with Blackstone. So far I've done 3k, 4k and next 5k. So far, so good at 124k miles.
Blackstone gave me specific recommendations that I could run the oil longer after my last test which is why I suggested you ask them.
edit: sorry, I didn't read clearly that the last response was from OP...Just do a full oil change along those intervals and send out a sample vs. trying to get one through the oil fill. But that just like my opinion, dude.
Thanks!
Thanks!
As an aside, I was finally able to view your report. Nice report. Nice low wear metals. But, you can see the classic Mobil 0W40 shearing. Your viscosities are at the very low end of the spec range. This is why I use and recommend Mobil 5W50. It stays in spec much better and has much better high temp shear. Also Porsche A40 approved oil.
Then as a scientist, you'd appreciate and respect having proper and reproducible testing and sampling methods. That's why Blackstone recommends you take the sample from the hot oil stream, after a period of flow. Not in the beginning, not at the end, someplace in the middle. That would be difficult to reproduce with a piece of tubing stuffed down the filler neck.
http://www.blackstone-labs.com/sampling-procedures.php
Bummer.
Anyone else know if there is a way to sample the oil from a 997.2 (without having to do an oil change)?
I suppose I could do an oil change at 2000 miles, then do the next one at 4000 miles, and so on, but it would be nice to see the same oil over time.
Too frequent of oil changes is not good either.
