Anyone separate leather cover from shift knob?
Anyone separate leather cover from shift ****?
997.1 C4S
My lever shift **** cover is beat up. I found a good condition replacement from a parted-out 911. Just the leather. I also researched the procedure to remove the shift **** and cover. So I'm good there.
However, it appears the **** and cover come as one unit when sold. Can't see an easy way to separate the two so I can replace just the leather. I don't want to replace the **** because it is a special Makassar unit that ties to the rest of the interior decor.
Local P-dealer said he thinks the two pieces are glued and you need to basically cut it to remove them from each other. That would suck.
Anyone out there in Renn-land ever tackle this one?
I did... and I have a macassar shifter.
I gotta think about this because it has been a while. First, don't cut it!!
See here for more info... under my posts, I talked about this issue.. .read up.
https://rennlist.com/forums/997-foru...-1-of-5-a.html
For me, it just separated by accident and I had a heck of a time getting it back together as leather isn't machined and has its own mind. IIRC, turn the hood/**** inside out and there is a retaining ring of some sort in there. When you get your unit, pay very very close attention as to how it is assembled.... I just remember having a heck of a time putting it all back together.
Good news, no cutting and it is designed to be unistalled, reinstalled.
Peace
Bruce in Philly
Peace
Bruce in Philly
