differences in C2 GTS and C4 GTS?
Other than the obvious of the C4 is 4wd, there is the reflective light bar across the rear deck lid and the added weight of the 4wd system. Are there any other differences on the interior that set them apart? the brakes are the same right?
Brakes are the same. The reflective strip, AWD and front spring rates are the only differences.
great, thanks. I take it the front spring rate is different because of the added weight of the AWD. So what is the weight difference between C2 andC4? couple hundred lbs?
Weights are in your manual.
Originally Posted by snake eyes
AWD cars come standard with Mechanical locking diff.
Also the AWD is electronic - from the 997 turbo
997.1 C4S does not have the reflective bar connecting the taillights, 997.2 C4S does along with LEDs, reshaped taillights and revised front bumper.
C4S is wider at the rear wheels than CS
OP asked specifically about the GTS versions. Body is wide for both the 2 and 4 versions of the GTS.
