Cracked windshield
Cracked windshield
Front windshield approx 2-3 inches from the passenger A pillar. There is a bullseye and an inverted L shaped crack. It is almost under a size of a dollar bill due to its unusual shape of the crack.
Any RL member used Safelite (or other repair shop) to get it repaired or replaced?
Is windshield just a dealership item (since it has the radio antenna)?
Thanks in advance.
Thanks in advance.
Price the dealer and safelite.
Do you have windshield replacement as part of your insurance coverage?
Is it out of pocket?
Fast forward 10 more years. When your getting your car appraised/judged, will Porsche windshield glass get you the concourse award, at the car show?
Same price? or close? I'd choose the dealer Porsche glass.
Plus you have someone to yell at if the radio or Nav does not work.
If you do use the Safelite people. Make sure you show them that all your radio and Nav works when you drop it off.
Use the dealer. I have many experiences and Safelite can be really sleazy both giving me misinformation about what is in my insurance policy and installing non-OEM glass.... that has visual warps in it.
Check out my threads
Thread on glass 1
Thread on glass 2
Another interesting thread:
OEM vs Non OEM glass
Peace
Bruce in Philly
Thread on glass 1
Thread on glass 2
Peace
Bruce in Philly
Dealers do not repair windshields. They have someone like Safelite or others come in to do the work. I have had Safelite repair a windshield on my 911. They did an OK job but the impact caused a delamination in an area the size of a quarter. It is visible after a few years but I will replace the windshield after the next event. My recommendation is that you have a windshield replaced at your home where you can supervise ( and perhaps even help). I had this done with a different car ( M-B E320) . I helped install the glass ( they knew I was picky). I let the car sit for 24 hours and then I was good to go.
Safelite botched mine, made things worse by refusing to acknowledge their incompetent work, then after escalating to their DSM who arranged for another Safelite shop to reinstall and fix everything they made it EVEN WORSE STILL by using paper towels to clean up all the excess sealant, which of course thoroughly scratched the paint, and capped the whole painful process off with a dent- which they of course denied being their fault. (They refused to let me watch, I sat as close as I could, so close I HEARD my car being hit, ran around the corner, saw a guy walking past swinging a wrench exactly the same level as the dent…. oh not that wasn't me...Arrgh!) All of which could have been avoided simply by me standing there watching.
Next windshield, home install, flawless work, less time, far less trouble, and I learned a lot too.
Unless you have personal first hand knowledge, always supervise. Always!
I just ordered an OEM windshield from Sunset Porsche; It's shipping today. $930 for the windshield, another $80 or so for seals, and $130 for shipping from Oregon. Still less than what they were quoting me here. My insurance will only pay for aftermarket, $710 total. I told them to take a hike. I'll send them the receipts and they'll send me the small penance. It's worth it to me to have the OEM. I'll look at changing insurance companies after I get my windshield fixed. I'm using my favorite body shop's installer to put it in; years of experience with Porsche windshields.
Give Sunset a call, can't hurt.
Called the dealer...they said they have "someone" that fixes the windshield for $175. I presume it's 3rd party.
Allstate recommended safelite. I'll get an estimate from both places either cases (repair or replace).
I'm leaning towards dealership.
cab windshield
Malexgcab, not sure if you have a cab or a coupe? When I replaced mine 2 years ago, I used the collision shop that the dealership uses, and they told me that using a Porsche (versus aftermarket) windshield is especially important for cabs. The windshield in a cab provides structural rigidity so the thicker glass from Porsche helps in this regards. In addition, if the installer isn't using factory glass, they probably aren't using the right glue either which is expensive but really holds it in there.
Mine cost $1,500 installed.
Official Rennlist Snake Slayer
Last time I needed a Porsche windshield, about 3 years ago, there was not an aftermarket supplier of windshields for the 997.2.
Didn't matter what the glass company said or ordered. All replacement windshields were OEM.
Just had mine replaced her in So Cal a couple months ago. Went through State Farm and they recommended a really good installer who told me they can use OEM if replacements aren't readily available - which one wasn't. So for the cost of my deductible I got an OEM replacement.
FYI, in case it can help anyone else.
