Missing Part - 997 C4 Hole next to Right front wheel
Hi There
I am missing a part near the front right wheel well. I am not sure if it's the brake cooling air duct shroud. Photos are attached.
ps. the silver tape was placed so can be easily located on the photo for orientation purposes.
Looks like you need an entire front wheel well section. Should be attached from bumper to upper wheel well where it meets the rear section. Appears torn straight across. What you are showing shouldn't be seen without wheel well removed. Compare to other front corner.
