Transmission Specialist in DC Area
Does anyone have a transmission specialist in DC Area? I have a small leak on a manual and the dealer can only offer to replace the unit. The transmission works perfectly so I'm not going to go to that expense. I'm trying to find a shop that can remove and make a repair on our transmissions. Thanks
IMA and ASG are the two commonly referenced local Indys. I haven't used ASG yet but will try them soon. I have mixed reviews on IMA at this point. Do not expect things to be done on schedule if you go there.
edit: are you referring to a rear main seal leak?
I've been testing the waters with him for about a year knowing that some pricey work was on the horizon for the 996. I've found his prices reasonable and he and his crew are happy to spend time giving you as much detail as you'd like. Some people might be put off by his gruff manner, but it's really that he doesn't BS which is a big plus in my book.
Every time I've been there, all the bay's are full and he has a backlog. My take from that is that he doesn't have to make work up or try to up sell you as the work finds him.
I was put onto IMA by someone near me that takes his 986 and 955 to Ivan for the stuff he can't take care of, including some transmission work on the P!g (rebuild?). To this point I'm happy so Ivan will have my business and recommendation for the foreseeable future.
