Inside door handle popped!
Got into my Targa today and when I went to get out of the car something popped off the handle and it is lamely in place and will open the door but do not want to trust it won't get any worse. Has anyone had this problem- 07 Targa 4 ? Anyone know how to repair ?
Thanks!
Thanks!
Yes, this is common. An internal part snaps as it is plastic and under pressure from a spring. Replacement does require removal on the door panel. I fixed mine on my own, but others have said that the replacement part is now updated and more tricky to replace. Suncoast does sell the part, and it alone is $50 or so shipped.
http://www.suncoastparts.com/product..._interiorDOORS
http://www.suncoastparts.com/product...S_InteriorDOOR
They are surprisingly inexpensive, considering how intricate they are. And I think the 997.1s used a slightly different cable attachment than the 997.2s. Just be sure you order the 997.1 version. Install is super easy.
Good luck.
EDIT: ^^^ Ha, we were probably posting at the same time.
It happened to me recently. The spring on the "Axle Bearing" snapped out of place because the plastic tap that is holding it is slightly broken.
1) I fixed it temporarily by putting the spring back in place. Needed to do it carefully without making further damage to the plastic tap.
I ordered the replacement part at the same time, but due to the slightly different design, it requires the new part "lock cable" as well.
2) the above fix lasted for about a month before it snapped again, the same day replacement part arrived! Replacing the "Axle Bearing" is pretty easy once the door panel is removed. But like other mentioned, replacing the cable is very tricky... the door lock and external door handle need to be removed (I think). At the end I gave up and just snap the original cable back into the new "Axle Bearing" with a bit of twisting and pushing. It worked and seems to be working pretty well.
This is how the parts look... http://www.ecstuning.com/ES2771010/
(I didn't from this link as I ordered it from a local shop)
I only replaced the left side, and will be doing the right side this weekend (I took the opportunity to replace / upgrade all the speakers), and can take some photos for you.
