Dash beeping sound on 07 911.
8th Gear
Hello car is a 2007 911 Turbo.
There is a faint almost 1/2 volume of the normal warnings coming from the left/front steering wheel area of the vehicle while driving. It will be probably in/out several times while driving. I did some searching and saw some people talked about key fob batteries tried both keys, did the same thing. I read about the IMMOBILIZER possibly having a battery that needs to be replaced.
It's not the speed warning that is turned off, or any other warning chime for seat belt etc.
Any advice would be greatly appreciated!
8th Gear
Immobilizer has no battery so you can rule that out and remote batteries don't beep. You said you ruled out the speed warning (beep isn't occurring at same speed, correct?) so maybe previous owner left behind a battery operated blue tooth receiver or there is some other aftermarket device letting you know that a battery is low. Can you ask previous owner?
