Review: 997.2 TechArt Springs, GT3 + TPC Sway Bar Install
Old 04-26-2015, 03:07 PM
ElectricChair
ElectricChair's Avatar
What a difference.. perfect height
Old 04-28-2015, 09:46 PM
EMC2
EMC2's Avatar
Thanks.
Each time I drive the car I am blown away by the improvement in handling.
The overall responsiveness of the suspension and the grip, plus lack of body roll in cornering are so much better.
Old 04-29-2015, 06:45 PM
Lvt19672
Lvt19672's Avatar
The polished lip on your wheels really set it off, did a shop do that and if so how much?
Old 04-30-2015, 10:46 PM
EMC2
EMC2's Avatar
Thanks - I had them done by a shop North of Atlanta. Cost was $1100 which included:
- tire removal/remount and balancing
- painting the wheels black as they were standard silver color previously (did not go with powder coat - went that route on the Cayenne Sport Design Wheels and they are a lot more difficult to touch up when needed)
- polished lip with lathe
Old 05-04-2015, 02:52 PM
nwGTS
nwGTS's Avatar
Did they install a new dogbone on the rear suspension? And I see you kept the stock toe control arms. Were they able to keep the alignment within spec with the new springs and dampers?
Edit: Can you provide the toe and camber specs they dialed in at the four corners?
Last edited by nwGTS; 05-04-2015 at 02:54 PM. Reason: Ask for toe and camber specs
Old 05-04-2015, 04:40 PM
EMC2
EMC2's Avatar
Correct - I had what looked like a worn rubber bushing on that dog bone so decided to replace. Control arms were not changed.
Here are the alignment specs.
Old 07-14-2015, 08:03 PM
slicky rick
slicky rick's Avatar
Thanks emc2 for sharing your project and experience. I hope you can advice from your research, ior others from their experiences, I f installing the springs on a pasm car, are there other parts needed besides the springs to do this project properly or do we need extra parts like dogbone links or camber plates to keep alignment specs within tolerances?
Really like the drop on your car emc2
Should have gone through whole topic, I see you were within tolerance but more on the aggressive side with negative camber... I should have mentioned for a more street driven vehicle where tire life is important, are there any extra parts needed to maintain the less aggressive alignment
Old 07-15-2015, 12:26 AM
Ten Years
Ten Years's Avatar
I like your style. Looks amazing. Love the Sport Design wheels in OEM look black with brushed rim. Is that the car the leather PDK surround went in? Congrats on setting it up exactly as you want it. ;-)
Old 07-25-2015, 11:48 PM
EMC2
EMC2's Avatar
slicky rick - apologies I only just saw your post.
I did not research what was needed for PASM cars, but I believe the part number for the springs is the same for PASM and non PASM cars. (note there is a different part number for AWD and Turbo models)
I would therefore assume you don'n need any "special"l parts, but I would certainly suggested updating some of the wear items whilst in there as I did.
Old 07-25-2015, 11:52 PM
EMC2
EMC2's Avatar
Hi Ten Years,
Yes it is indeed,
Installed and looks great - thanks again
Old 07-26-2015, 12:46 AM
Chaos
Chaos's Avatar
Thanks for great write up!
Old 07-26-2015, 02:52 PM
awrryan
awrryan's Avatar
Originally Posted by EMC2
Hi Ten Years,
Yes it is indeed,
Completely jealous of your sport design steering wheel. Looks amazing
Old 07-26-2015, 03:08 PM
EMC2
EMC2's Avatar
Thanks Ryan. I bought it from Suncoast and it was one of the best interior updates for the money + it only took a few minutes thanks to some really useful DIY videos on YouTube.
Old 07-26-2015, 04:09 PM
awrryan
awrryan's Avatar
And there's my next "project!"
Old 07-26-2015, 04:10 PM
Ten Years
Ten Years's Avatar
Hi Ten Years,
Yes it is indeed,
Just seeing this now. Wow! Looks perfect. Love your car, overall.
Quick Reply: Review: 997.2 TechArt Springs, GT3 + TPC Sway Bar Install
