View Poll Results: Heel and toe approach?
Traditional - stock pedals
![](https://rennlist.com/forums/images/polls/bar2-l.gif)
![](https://rennlist.com/forums/images/polls/bar2.gif)
![](https://rennlist.com/forums/images/polls/bar2-r.gif)
![](https://rennlist.com/forums/clear.gif)
20
27.40%
Traditional - aftermarket pedals
![](https://rennlist.com/forums/images/polls/bar3-l.gif)
![](https://rennlist.com/forums/images/polls/bar3.gif)
![](https://rennlist.com/forums/images/polls/bar3-r.gif)
1
1.37%
Rolling/side of foot - stock
![](https://rennlist.com/forums/images/polls/bar4-l.gif)
![](https://rennlist.com/forums/images/polls/bar4.gif)
![](https://rennlist.com/forums/images/polls/bar4-r.gif)
31
42.47%
Rolling/side of foot - aftermarket
![](https://rennlist.com/forums/images/polls/bar5-l.gif)
![](https://rennlist.com/forums/images/polls/bar5.gif)
![](https://rennlist.com/forums/images/polls/bar5-r.gif)
13
17.81%
Don't heel/toe
![](https://rennlist.com/forums/images/polls/bar6-l.gif)
![](https://rennlist.com/forums/images/polls/bar6.gif)
![](https://rennlist.com/forums/images/polls/bar6-r.gif)
8
10.96%
Voters: 73. You may not vote on this poll
Heel and toe
Thought it would be interesting to see the approach to heel and toe by enthusiasts.
Traditional (actually using ball of foot on brake and heel for gas)
Rolling (using the side of the foot)
And then whether using stock pedals or aftermarket.
Shoes size might be an interesting addition too.
I do find the stock pedals less than ideal for that technique. Find it much easier to do in my BMW.
It might be a technique issue for me too... but getting something that widens the gas pedal a bit is compelling...
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
roll, aftermarket pedals.
I have more pedal control in this manner in my opinion. I wear a size 13 sneaker so its a bit difficult to cram that onto the pedals, especially in the narrower 993 pedal box.
Yeah, size 13 shoes and even w/driving shoes, I don't have the confidence in the footwell vs. knee in the wheel vs. contortion to get the traditional blip going. All that and what is probably not great foot technique... though, again, BMW is much easier for me.
I better get myself an aftermarket kit on (I know there are separate threads on this). What is interesting from the poll so far, is the nearly 50/50 split in the technique usage and that most who roll use aftermarket pedals...
I'm a roller, 8-1/2 D size shoe, stock pedals. Heel stays planted on the floor between the two pedals, but moving the right knee to be centered over the brake pedal when braking is initiated allows me to rock my entire leg for the blip--rather than trying to do it using just the ankle's range of motion. Also it's less stressful on my knee in the big brake zones at the track. Read that tip somewhere, made a big difference for me. Data shows some room for better consistency in maintaining brake pressure during the blips, though.
I have the Rennline pedal set and currently use the rolling technique, but need to overcome the long leg issue and learn traditional technique for the track.
The problem is that any muscle memory developed with the rolling technique in street driving is useless on the track since I'm so much deeper in the brake pedal travel when on the track. It makes the relative positions of the brake and gas pedals completely different from street driving.
When I lower my seat and raise the wheel a bit I can slide my knee over and get in that position where I can mash the gas pedal with my heel, but that's a weird way to drive around on the street.
Any advice regarding how others have developed reliable track techniques would be appreciated. It feels a little risky to get this all worked out exclusively on the track while potentially screwing up a braking zone, overcooking a turn in point, and the resultant "off" at speed.
The 'Traditional' method of heel/toe is anything but these days. The term is from an age where pedals were located differently than today's clutch-brake-gas arrangement. I think it was clutch on the left, brake on the right, and the gas pedal somewhere down and in the middle. The term however lingers on.
Rolling the ball of the foot is the way to do it and aftermarket pedals make life much easier than the stock arrangement. Have a look at SRP.
I guess I am somewhat in between the 2 options. I have long legs (shoe size 12) and initially "rolled" but since I got my Suncoast pedals (which are awesome BTW) I am trying to learn the traditional technique. I found it tremendously difficult to practice this on the street though, because I hardly ever have to brake hard enough to make it realistic.
Aftermarket pedals, roll my foot. I find that the 911 bottom hinged gas pedal makes the heel part of the heel/toe almost impossible. Rolling works perfect on track and aggressive street driving. Size 10.5 shoe
At 6'4" I have a problem with tight leg room and the steering wheel gets in the way. I also don't like how the factory pedals are positioned and I was surprised when I first got the car that heel and toe was so difficult. I had no problem in my C6 Z06.
I would need different pedals and a smaller steering wheel. In the mean time, I rev match when down shifting by tapping the gas pedal beforehand.
My late father drove a little '64 VW Bug to and from work every day. We lived at the bottom of a long hill and he had to turn right, and then right again, to get into our driveway. We knew he was almost home because we would hear him heel 'n' toe the little car, matching revs perfectly, right before braking for the two turns into our house. Brings back memories.
