Factory is thru the DME, on my 06 and later my 09, I direct wired it to the fuse box, when I installed.
No DME cut off, need extra on/off button. (Mine's in ashtray)You cannot use the dash button supplied.
Is the PSE button connected directly to DME? Where can I find more info about the PSE button's wiring?
The TSB for retrofitting the PSE has some information on how it's wired. It's available on Renntech for donating members. I also installed my PSE switch to a relay so I can control the on/off feature. It was a little of a PITA but I was able to do this with a modified version of the stock PSE button. Looks 99% stock. The only thing I could not replicate was the little yellow led that illuminates when turned on. I couldn't find an led sturdy and small enough for my application. This was 3 or 4 years ago when I did this so maybe one is available now.
