PSE cut-off
My idea, if works, it will costs probably the same and it will require few extra minutes of work. It will replace the switch with a relay that will have the same function and it will add one maybe two more wires. One of these wires will tap into the PSE or Sports's button Led wire (no extra risk) and the other one should go to ground. That's it.
I identified the Sport's button led wire.
To do:
- Identify the led's voltage
- buy the proper relay
- install it
- (i'd like to install the relay in one of the front/back relay boxes if possible)
