Engine smoking on arrival, antifreeze leaking out the back right now...
That caught my eye too. The proper antifreeze for our cars is reddish/orange and is chemically different from the green stuff. Using the wrong one or mixing the two is not good. While you are getting this fixed you may want to consider getting a thorough flush and restoring the entire system with the "right stuff" (which is also a "lifetime" coolant although some change it just for due diligence).
If you indy did this somewhere along the line, you may want to consider a new indy who knows Porsches.
The traditional green coolant was designed for cast iron blocks. Most modern engines are entirely of aluminium construction, including the water pump impellors.
The color indicates the chemical content which are different in each type. So mixing colors is a no no, as well as using the wrong type.
https://rennlist.com/forums/997-foru...-part-1-a.html
Also correction to my title - the waterpump failed right as I pulled into my garage - the "smoke" was likely heavy steam from the coolant leaking.
My wife's did the same thing. Floor was dry when she left to take the kids to school, and a puddle was there when we left for lunch. Seems like that's the way they fail, not a drop today, 5 drops tomorrow, etc
Are water pump failures really that prevalent in the 997.1 ?
I remember reading in another thread on preventative maint that it was a significant problem in the 996 but not nearly as bad in the 997 ? This was based on dealership stats.
This being said, I will probably replace mine 60K'ísh.
Are water pump failures really that prevalent in the 997.1 ? I remember reading in another thread on preventative maint that it was a significant problem in the 996 but not nearly as bad in the 997 ? This was based on dealership stats. This being said, I will probably replace mine 60K'ísh.
Now that 997.1s are getting some mileage on them, we will start seeing a failure pattern.
Your plan sounds good.
Sent from my iPhone using Rennlist
