Sport Bucket vs Hardback Sport Seat
How is it not clear? You SIT significantly lower, it's very hard to measure, as the back of the seat is lower than front and I can't measure from the back of the seat to the floor.
No measurement would help unless you go and sit in one. I did that before I bought mine. As I said, it's great for track but kinda hard to get in/out of the seats.
Here are my Hardback Sport Seats measured at identical points as sandwedge's Sport Buckets
Both seats are set all the way to the lowest setting (closest to the floor) and all the way back.
I plumb bobbed one line from the headliner to the rear of the seat and another to the front of the seat.
Here are the measurements:
Sport Buckets
Rear of seat to headliner: 39.25"
Front of seat to headliner: 29.5"
Hardback Sport Seats:
Front of seat to headliner: 30"
They are basically the same height off the floor.
And now we know.
Sport Buckets
And now we know.
Egress involves moving one's legs over the side support before being able to exit the car. I've noticed this myself when I sat in another 997 equipped with Sport Buckets. So, I'll also assume that's the 'difficult' part to which others refer.
If you are in good health there is no reason why the minimal extra effort in egress with the Sport Buckets should prevent you from preferring them over the benefits of lateral support, weight savings, and five point harness support. The additional cost on the other hand.....
Not hard at all really, you'll develop a method that works for you. Parking where you can fully open the door is a huge help. Some people like to slide the seat all the way back for entry/exit and slide them into position when they sit down.
By GT2 seats I'm going to assume you mean the Sport Buckets. Other members have anecdotally attributed difficulty in egress to the deeper bucket on the Sport Buckets compared to the Hardback Sport Seats. They are the same height from the floor as the Hardback Sport Seats as you can see. The deeper bucket on the Sport Buckets is a result not of a lower seat but of a higher side support to brace the hips and thighs in high-g cornering.
Door fully open will not be a problem as I have lots of room at work. Thanks for the tip.
So, as I said earlier, I have no idea WHY someone would want these seats if they don't track their car. I guess if it's going to be a weekend/track car, it's fine, but as a daily, it's absolutely more difficult. I have had the seats for 3yrs but use it only in summer, and as it's my daily I know how it works in real life.
I totally disagree. I am 6'2 and I find it hard to get in/out. Basically to sit in, you have to sit sideways first (feet out), then turn into driving position. What you said "parking where you can fully open" is absolutely right, and that's a big problem as it's quite difficult in tight spaces to do this...
Sport Buckets
And now we know.
Sport Buckets
And now we know.
Mine is a daily driver. Getting in and out is different but as with everything else that's different you develop a method and soon enough it becomes second nature and a non-event. And whether you track the car or not I think most will agree that the buckets add another level of connectivity with the car.
