Saaboteur's 06 X51 Carrera 4S
I also own one of the few 2006 C4S with X-51 (mine also has the aerokit). You made a great choice as I absolutely love my car, especially how easy it is to maintain from a DIY perspective.
Regarding X-51 and PSE, my sport exhaust is selectable with the "SPORT" button. If I recall correctly, when I push the SPORT button, both it and the PASM button (the one with the shock depicted) illuminate. If I don't want the stiff ride but want to listen to her growl, I just deselect PASM and the PSE stays active. I hope I didn't get the buttons backwards, but it's fairly intuitive.
Sean
Sean
Lovely car and pics.
Sean
Sean
Sounds like PO has unplugged the electrical connector from the PSE control valve.
Check this picture. Found it here on another thread. The control valve is the gray box with the two vacuum lines and orange electrical connector. Some owners pull the elect connector and PSE stays in loud mode. check under your hood.
While you're there take a pic of your X51 kitted engine and give us a looksy.
Congrats on finding a beautiful specimen of the 997 !
We have an X 51 in common. My car has Aero Kit and a PSE button. Also have short shift. No TPMS. Great car. Drive it and enjoy. Drive it into a dealer. They will help. X 51 is a rarity and dealers love to look at your air box! This option requires a built to order car in the USA. Almost $17k for X 51 alone. It is like an M Powerkit on BMW only no M markings. Very cool.
Well, I had a nose around the engine bay and couldn't find that connector. I will have another look again in daylight though.
As for the bumper holes - bumperplugs.com! The hood actually has a few small chips, from road rash. Eventually, to be basically back to perfect, the hood and front bumper could be repainted. At that point, I would have the holes filled in. I pity the jurisdictions that require front plates, ruins the lines of a car like the 997.
Congratulations and welcome - pretty car. I really enjoyed the story - you could write for one of the auto publication
FYI, you don't need to give up memory seat functions with the sport seats. Get the Adaptive Sport Seat Plus versions and they're fully electric including 2 switches on the front corner to adjust the upp r and lower side bolsters. I retrofitted them into my RUF C2S - simply plug and play (disconnect the battery when doing the swap to avoid an airbag error code when done).
You bet. I just wanted to clarify to the OP how the set-up works on my X-51. It appears Porsche made no alteration to this function with the powerkit option.
Saaboteur -- I definitely can tell a difference when my PSE is selected and when it isn't (even with the windows closed). It's not something I have to listen for closely. Those X-51 headers are great which is why I will never make any mods to my exhaust.
Sean
Sean
Congrats!!!
Sweet car. I saw that car at wiessach, so my apologies if a little of my drool is still on it... Cool pics, I def had the same feeling when I got my 996tt, couldn't sleep.
This is how all the PSE equipped 997.1 that also have PASM work.
The car will actually drive better with PSE functioning the way the factory intended. Even in Sport mode, the computer will sometimes close the valve and then reopen it. It does this to optimize the exhaust setup - at low RPMs like when leaving a stop, the engine needs some backpressure from the exhaust to build torque then as the RPMS increase where you want more efficient breathing and more HP, it will open the valve. Having it manually defeated (unplugged) where it's in Sport mode all the time defeats some of the designed functioinality. Plus, it's nice to be able to manually put it back in quiet mode, like when driving next to a police officer or leaving your neighborhood early in the morning for a flight.
Might want to consider having the holes "plastic welded"...they did one at Norden/Porsche Centre on a similar colour and it looked great.
http://www.rennline.com/Screw-in-Lic...info/E107.108/
Of course this has to be done initially before the holes are drilled into the front bumper.
