Speed Control doesn't initiate
Hi,
My speed control won't turn on. I press the button on the end of the control, but the light on the speedometer does not light, nor can I set a speed. Has anyone else come across this issue and found a simple fix?
Thanks in advance,
Greg
Thanks in advance,
Greg
If the fuse book doesn't show a cruise control fuse check the owners manual or swing by the dealer and have the parts department clerk look it up on his computer.
Interesting result: I took a guess as to which fuse was most likely, and pulled b3. I checked it and it looked fine, so I re-inserted the fuse. Next time I started the car, I got a PSM failure message on the dash warning system. I cleared it, and I have not seen that message again. Since the fuse was OK, I didn't think to check the cruise control immediately, but this morning (about 4 starts after the fuse remove/reinstall), I did click the speed control button and it lit and the cruise control is fully functional. So, keeping my fingers crossed...
