Yellow Dots on New Tires...Matter if They Aren't Lined Up with Valve Stems?
Got some new tires mounted yesterday. The valve stems aren't lined up with the yellow dots on the tires. Does that matter? I Googled the yellow dots and found these are supposed to be the light point on the tire, and as such a good spot to put the valve stem to aide in balancing. Wondering if I should take the car back to the tire shop and ask for a redo? Car drives smoothly, though I've also not been able to get up up to any real speed yet.
Thanks in advance for the help.
Received 5,407 Likes
If they are balanced, then they are balanced. Don't fret about it.
Now go wash off those ugly yellow dots.
I think it shows that a tire installer doesn't know what he's doing if the dots aren't lined up, as they're there for a reason. It is entirely possible to balance a tire if these are not lined up, however.
I would be annoyed if the dots were 180 degrees off and there was a big clump of weights stuck to the wheel on that side, as that could have been avoided by installing the tire the right way.
The weights are unsightly, mar the paint when they're removed and--very occasionally--shed and throw the wheel off balance. Lots of weight in one spot is also indicative of a bent wheel or bad tire, so I am always paranoid when I get a wheel back with alot of weight added.
Shedding weights, of course, was way more common with clip-on banana weights than it is now with stick-on flat weights.
Valves are I'd guess about 20 to 25 degrees off alignment with the dots. Could the wheel lock lug affect the positioning since its a bigger lug? I'd guess the weight strips are in the 3-4 inch range on each wheel.
I always put the locking wheel bolt directly across and furthest away from the valve stem position.
I have never thought about the locking lug bolt position. I assumed they were so close in size/weight and so close to the axis that it would not affect anything. Now I will have to pay attention when I install my tires even if it will not make a difference.
First thing I do when I get a new car, or a new car to me is remove the locking lug bolt. The only person it inconveniences is the car owner. The bad guys are going to take the whole car, or smash the window to get the mag key in the glove box or frunk.
Little dot not lined up? And the car does wobble. Don't worry about it. I have had more than my fair share of tires and rims. I've even had tires and rims balance and they needed NO added weights. Yes they were perfect. I stood there with the installer and watched them balance up perfectly. That was weird.
For your own sanity call the shop and comment. Take a photo now, for that just in case call back in a week.
Also note that the stem is not necessarily the heaviest spot on the wheel. Sometimes machining etc mean that the wheel isn't perfectly balanced. If you have access to a dynamic balancer try running a wheel on the machine without a tire at all. You would expect that the machine would tell you to put weights 180 degrees from the stem. That's not always the case.
All correct. Its balanced no need to worry. But for me tire companies put it there for a reason. Yellow dot lines up with valve and also the lock lug. Including the tip of the porsche logo in the center cap. All these items should line up. This is the right way of doing things. Mediocre or exact. Your choice.
