Show me your 997 with non-Porsche wheels
#1712
That front wheel is 2mm inboard of the 20x9"ET50 we have sold to a few 997s before, worst case scenario is you will need to move your front strut top mounts inboard on the factory slotted mounting holes to get a few more mm's of clearance. The rear should be a non-issue, you may even end up throwing a spacer on it after you get tires mounted to have it match the front fitment. Something like 235/30-20 and 305/25-20 is likely the tire sizes you want to keep them from being too tall. A 245/35-20 front tire will be far too tall and will hit the fender liners while turning.
- Brandon
- Brandon
Did i get it right, rears should be with lower profile than fronts? You were saying i should be looking at 235/30-20 fronts and 305/25-20 rears, wouldn`t that look odd fronts 30 and rears 25, or it is not that noticeable on car? Sorry it`s my first time buying wheels and tires for car which has different sized wheels, a bit frustrated
#1714
Hi Brandon,
Did i get it right, rears should be with lower profile than fronts? You were saying i should be looking at 235/30-20 fronts and 305/25-20 rears, wouldn`t that look odd fronts 30 and rears 25, or it is not that noticeable on car? Sorry it`s my first time buying wheels and tires for car which has different sized wheels, a bit frustrated![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
235/30 and 305/25 are fine but they have a very thin sidewall. I run PS4S in 245/30-20 and 325/25-20 on my 20x9 20x12 setup and those sidewalls are pretty thin but larger than the former.
Next time around I’m going with 255/30-20 in front as the 245s/325s are a bit stretched. I’d also go with 335/25-20 if the PS4S were available in that size but they aren’t.
#1715
Hi Brandon,
#1716
You are trying to plus-size (go bigger) than OE spec with the 20" wheels you just bought. Ideally, you want to maintain the same aspect ratio and rolling diameter of the OE wheels/tires from the factory. Use this calculator to figure out the closest spec tires that will get you to OE aspect ratio: https://www.calculator.net/tire-size-calculator.html
The calculator will tell you how close to original 19" factory spec your new 20" setup will be and how it will affect your speedometer reading. I suspect you will not be able to get exactly to OE but you can get close. Good luck.
Hi Brandon,
