What is involved in "turning a 4 into a 4S" and is it possible?
As I get closer and closer to buying my 911 I'm somewhat torn between the 4 or 4S. On one hand either one will be amazing but on the other hand I do plan on keeping this car a long time.
If I bought a 4 is it possible for me to just pay to have certain things added/changed to essentially make it an S? Or are there certain elements that are only available if you start with the S model?
Maybe a dumb question but I had to ask.
Thanks in advance !
Thanks in advance !
PASM is most likely the most important aspect of the S package. The ride is quite a bit smoother on the road when you want it to be and firms up with the touch of a button.
The extra HP and torque is nice as well!
PASM is something that can or cannot be added to a non S model?
before you dig any deeper.
main differences:
* bigger engine
* Bigger (red) brake calipers
* white instrument face gauges
* PASM
* quad exhaust tips
retrofitting all this will be very expensive.
If you're already on teh edge you will not be happy with a base model and later regret it
So, buy an "S" and be happy from teh get-go
main differences:
* bigger engine
* PASM
* quad exhaust tips
It is expensive to retrofit and, come resale, it will still not have the badge on the back so i struggle to see you will get VFM from starting with a Carrera 4 if you just spend your ownership wishing you had the S spec.
I just had a chance to drive two 911's back-to-back this past weekend, a 997.2S and a base 991.Even though my comparison wasn't "apples to apples", it was sufficient to show that, in addition to the mechanical changes that have already been mentioned, the driving "feel" of the two engines is very different: the S has a lot more torque down low in the rev range. I could tell very easily just by pulling away at normal speed from a stop. So, test drive the two cars and see how you like the softer, gentler driving experience of the base model. You may like it or you may not, but it will be quite obvious. I think that converting a car from a base model to an S after the fact is not going to be feasible in a practical way.
Colin, don't make the mistake of buying a 4 when you really want a 4S. The extra cash now (not much, mind you) to get into a 4S will probably save you money down the road
Thanks in advance !
Thanks in advance !
