No Brakes
I have a 2009 C2 Cab (997.2). I changed the front brake pads and the pad wear sensors today.
As part of this process I disconnected the the brake lines so that I could remove the caliper to change the pads. Some brake fluid came out from both the left and right lines.
I put everything back together and there aren't any leaks, but I did need to add almost a full bottle of brake fluid.
Now the fun begins. When I press the brake pedal it goes all the way to the floor. I drove around the block a couple of times and pumped the brakes. It is very spongy. I have to push the pedal right to the floor board in order to stop the car. I spent about 20 minutes pushing the brake pedal hoping that it would provide normal resistance, but it hasn't. It is still very spongy and the pedal goes to the floor.
So, what do I need to do to fix this? This car is my daily driver and the dealer service is closed tomorrow and Monday.
Do I need to bleed the brakes or should I flush out all the brake fluid or something else?
Any suggestions are appreciated.
Thanks.
Also when was your last brake fluid flush?
Before you do anything (if you haven't finished the job yet), review these 2 DIY threads on bleeding brakes:
https://rennlist.com/forums/997-foru...ake-bleed.html
https://rennlist.com/forums/997-foru...fluid-job.html
If you only set out to change your pads, you created much more work for yourself. You do not need to remove the calipers to swap the pads. There are some DIYs on that subject as well. In fact it took me 30 seconds to find this video on YouTube.
In the future I highly recommend you look through the 997 DIY tech index here on Rennlist (and search Youtube . . . there are tons of great videos), especially if it's been a while since you've done a particular job. Good luck.
Sean
Sean
Yep, Definitely got air in the brake lines. just do the complete brake flush and you'll be GTG.
I know what you're going through. I had something like this happen the first time I did a complete brake service on my wife's BMW (her DD) and I ended up having to take the car to the dealer for them to finish what I started. I was embarrassed all the way around. Fortunately, not only did the dealer not rake me over the coals to fix my mistake, they even gave me a loaner. Fortunately, THAT mistake will never happen again.
Lesson learned - don't start a DIY job on a DD unless you have a backup plan for if things go unexpectedly wrong
Well, now you tell me :-). It is difficult to get the pads out unless the caliper is disconnected from the break line on a 997.2. I think that I can take off the break line mounting bracket though and that would give me enough room to pivot the caliper around to access the pads though. Lessoned learned.
Porsche Brake Pads replacement in under 9 mins.. - YouTube
Sean
Sean
I used the instructions from here to do the job.
https://rennlist.com/forums/997-foru...rake-pads.html
So, I am not clear on how this is done without removing the break line. Also, it is a real pain in the butt to reconnect the break line as well.
