Forgestar F14 - offset for C2S
Hi Bros,
I'm currently considering the Forgestar F14 for my C2S NB, but would like some advice on the following:
1) the size will be 19x8J front and 19x11J rear. What should be the correct offset?
(I'm going to be re-using my 5-months-old PSS 235/35/19 and 305/30/19)
2) I'm currently running the Porsche original Turbo Style wheels for C2S. Money aside, is it worth swapping to Forgestar F14 for performance (lighter and stronger)?
Thanks.
Thanks.
Spacers decrease your offset. So, for example, if you added 5mm spacers around it would be equivalent to offsets of 52 in front and 62 in back.
There are tire offset calculators you can Google which show before and after so you can see the impact of different size wheels and tires.
Hope that helps.
Hope that helps.
Hi Bros,
Thanks.
Thanks.
Thanks. That's what I heard as well. So I guess this change will be for cosmetics only then. I'll have to look into the offset issue further.... I have a C2S and the wheels came off a C4S.... waiting for owner to confirm the exact offset.
I spec'd mine with the below specs. I wanted flush fitment and they're spot on. No rubbing, no spacers. Optimized footprint.
19x8.5 +46
19x11 +52
![](http://i284.photobucket.com/albums/ll7/TrBlazer/Carrera%20S%20997/P997-0791_zpsedcb434f.jpg)
19x8.5 +46
19x11 +52
![](http://i284.photobucket.com/albums/ll7/TrBlazer/Carrera%20S%20997/P997-0860_zps45d0ec7b.jpg)
The car is a C2S and the rears are 305s
