Wiper Cowl Panel Faded
Newbies Hospitality Director
Just as it did on my 996, my wiper cowl panel (the plastic part located in front of the windshield, and under the windshield wipers) has faded to a medium gray color and I figure it will be light gray by summer's end.
Suncoast Porsche has a replacement part for $125 (the 996 cowl was $63 IIRC) excluding the two tabs on either end, which are $5.95 each.
Wiper Cowl Panel
While that is not a lot of money, it seems a waste to throw away something which is still functional, but just needs a cosmetic upgrade.
Has anyone ever tried to paint the cowl with spray paint formulated for plastic?
I was thinking this might be a good project.
Thoughts?
Wiper Cowl Panel
Thoughts?
Yes, I recommend Meguiar's Gold Class Trim Detailer. It restores and maintains original richness to dark plastic and rubber. I have used it on several 911s and especially on the area you are talking about. It lasts several months depending on sun exposure and car washes. It costs about $7 for a 10oz bottle and lasts years as it just takes just a little on a clean rag. Only downside is it easily smears on the windshield but wipes off pretty easy. Try it. GL
I've had great results with Forever Black Bumper & Trim: http://www.foreverblack.com/products.html
It has a black dye that does wonders on faded exterior black trim. Be sure to wear gloves so your skin doesn't stain. No affiliation, just a happy user.
I had exactly this same problem, and the only thing I could find that didn't just wipe or evaporate off was "Wipe New". When you use it, you've got to make sure that you've cleaned the plastic part well, and it is dry and not dusty. I've had really good results with it, it's what I would call "semi-permanent".
Consumer Reports recommends ReNu Finish or Wipe New for longer lasting results in May 2014. Costs more but lasts longer than other products.
303 doesn't last that long and while I have not tried Meguiar's Gold Class Trim Detailer, Back to Black, or Forever Black Bumper & Trim., I am wondering if they too are temporary fixes.
Chrono, I was thinking the same thing. If the paint doesn't work out I am out about $8 - $10 and a couple of hours of my time, then I buy a replacement.
I would be curious to know how paint turns out if you follow through with it.
I use 303 on mine and have since new so it's in perfect shape but I expect with time that could change.
I like the idea of asking the Bumper Plugs guy if he will paint these!
