Dealer screwed up my car coding, lots of durametric Q's
Semicycler - If you could also post yours. THanks.
Start at the lower section of Gateway-->Coding:
Sound Exhaust System : change to Installed for Porsche Sport Exhaust (PSE), you should have a button on your center console
Seat Heating: Installed if you have it
On-board Computer: I believe this is to enable sport chrono, installed if you have it
Cruise Control: Installed if you have it
Slide / Tilt Sunroof: Installed for Coupe & Targa, not installed for Cabs
I think On-Board Computer is something to do with PCM-cluster talking as I had also lost ability to display radio and tel details on my cluster with this off.
Reflashing should be pretty brainless and is a way better place to start.
I have a durametric pro and played with coding, and I came to the conclusion that there is just not enough info out there and the product is not well supported by the vendor. Also, some of the coding just doesn't work despite what the menu tells you. I decided that coding is just too risky for me.
Some found that saving and reloading cofigs just doesn't work...very worrisome.
Peace
Bruce in Philly
+1
Peace
Bruce in Philly
Peace
Bruce in Philly
Completely agree with you. I am able to code turn signals and remote windows. That's about it. Complete waste of money. Didn't even show me errors steering column had. Didn't even know about it until I complained to the dealer about car not starting as soon as you turn the key. So they found some errors that were causing delayed engine turnover.
Had to pay dealer to code the Chrono to be on as well as this thing can't do it.
In the end, waste.
Just curious if you have discovered the problem. Fried ECU? Engine replaced?
Not sure what you mean - the original problem was that the dealer screwed up the programming in my car, which I have by and large sorted out.
Never found out why the ignition hours are like that, if that's what you mean!
