Octane preference
After the TPC turbo goes in next month 93 will be my minimum......then maybe methanol injection.......and a supply of Torco handy for spirited driving tests.
With the proper octane the fuel can be ignited and be burning fully and making maximum pressure in the cylinder when the piston/rod/crank is best positioned.
With a bicycle you can get a taste of what this means. Normally one senses when is the best time to apply downward pressure to the pedal to obtain the most benefit from one's pedaling effort.
Try (force yourself) to delay slightly applying this pressure to the pedal. You will immediately detect a drop in performance.
With the proper octane of fuel the engine's more efficient, tractability is at its best -- there is a saying while we buy horsepower we drive torque -- and a tractable vehicle is a more enjoyable to drive.
Fuel economy is as good as it can be and last but not least exhaust gas temperatures are lower than they would be with a lower octane of fuel so engine wear/tear is reduced.
The ethanol is a horrible fuel additive -- its greenness, or lack thereof, is my major reason for disliking its use as a fuel additive (extender/supplement) but it is rather harmless to the car's fuel system and engine and exhaust.
There are many of us say in CA who have used nothing but gasoline with an advertised 10% ethanol (though I understand refineries while they could go to 10% stopped at 7% to 8%) with no harm. My Boxster for example has covered over 281K miles and has all its original fuel system components but the fuel pump. The converters were fine save for one that had a loose brick. It worked most of the time save when the brick fell out of position. The other converter though had no loose brick and worked very well even after all those miles. Plug life has been good and O2 sensor life also has been good.
Thus while I can still *hate* ethanol for the dirty fuel it is (when its entire pollution footprint is taken into account) I can't find any other reason to hate it.
I simply don't understand the stupid rules, why not make it at least available in limited supply for cars that require it. I cannot even imagine how classic cars would run with such crap gas.
