Tire question. Is wider better? 305 vs 295
QUick question about going the other way. - The factory tires are 305's on the rear of my 997.2 Targa. I was looking into all weather tires, and Tire Rack said the only ones were 295's which would fit fine on my car. Any thoughts?
Is your car lowered? If it's lowered or your even thinking about lowering it stick with 295. On the street I found no difference between 295 and 305 with Bridgestone Potenza RE050A. Michelins might be wider between sizes. I would look at the tire overall width spec!
http://www.tirerack.com/images/tires...dimen_2010.gif
Jim
The only issue with some 305s on 11" wheels is that the additional rolling diameter will change final drive, i. e. longer gearing... I have felt a difference between multiple brands, but love the look.
Also, C4S runs 305s on an 11" wheel with just an offset change, not an 11.5", so don't stress it, just go with what you like.
997.1 C2.
And any choice you can think of... PS2s, Bridgestones, and Hankook RS3's. Have a set of 305 Super Sports also, but haven't mounted yet. Never rubs, even when sitting lower with negative camber settings for track.
