Sports suspension question (s)
me too...
So would my 2009 C2S have LSD because I have Sport PASM? Or is this just a GTS thing? I got my VIN decoded from Suncoast and I did not see the stand alone LSD option code on my car...is part of the Sport PASM package??
And to the OP...the whole thing IS very confusing until you get a car and start messing with a bit, then it will make perfect sense on how everything works. Porsche confuses the $hit out of things with their acronyms and other naming...PSM and PASM for instance...they sound like the same thing and as you've read they have NOTHING to do with one another. At any rate...YES make sure you get a car with Sport mode...you'll love it and appreciate it!
I do think if you have factory SPASM option, you also have limited slip. Not specific to the GTS as far as I know.
The lower ride height of the sport suspension is a fantastic option, and stiffening the suspension temporarily for speed bumps, driveways and drainage channel's in intersections will save your front spoiler lip.
I never said I did not like the ride. I thought the original post was looking to see if you can adjust the suspension for LA roads. I simply commented that the ride is always going to be rough.
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
WOW! could this be a symptom of LSD? my car does this as well, going forward or back, there is a kind of hopping or muddled movement, I thought it was in the front end, but what do I know, and with the X51,maybe that is in there? anyone else notice this?
We can agree to disagree, as in my experience, the ride is not "always rough." Los Angeles roads and freeways are 3rd world in many places. That's when I turn off the stiffer suspension at the push if a button.
Does this happen more frequently, or is it more noticeable, when the weather is cold? If so, I think that is perfectly normal because of the high performance tire tread compound getting hard when temperature drops. All my 911's have done this. Why would it be related to LSD if it is your front tires making the noise?
I find that pasm on very rough and bouncy but pasm off is very very cushy but i'm used to driving japanese cars lowered on race coilovers. I guess if you compare it to a luxury suv then the 911 is always going to be rough
If the OP is expecting a plush, cushy ride, he might need to reconsider getting a 911, whether it has SPASM or PASM.
That weird wheel hop is likely the tires.
Performance tires will have a hard firmer rubber sidewall and will hop in reverse with the wheel to full turn radius. You should look for a tire with a softer sidewall if you want to eliminate that hop.
Less to no hop at all in reverse or accelerating out of a turn with a tire not designed for summer high performance or racing like most Porshe standard tires ie Michelins.
It's not a bother in the least, just something I noticed.
- Standard (on Carrera)
- PASM Suspension (10mm lower, sport button to soften/stiffen)
- PASM Sport Suspension or SPASM (further 10mm lower, sport button soften/stiffen)
So, in this order they go from soft/higher ground clearance to harder/lower ground clearance. If you primarily just do streets and are worried about pot holes, probably it's best to stick to regular PASM.
