Sports suspension question (s)
Hi all,
Again, thank you in advance for all your generous knowledge!
The same car with the center locks also has Sports Suspension.
My question is, in the rough roads of Los Angeles that I drive on everyday, will the Sports Suspension knock out the fillings in my teeth?
Joking aside, I think you know what I am asking, yes? Is this option mainly meant for racing?
I don't ever plan on tracking the car, so is this option a liability for me, not an asset?
It cannot be switched off, right? Also, it lowers the car 20mm, if I am not mistaken, yes?
Again, thank you all!
Steve
Steve
Hi all,
Steve
Steve
When on, It is stiff, but not GT3 stiff. I live in LA too, drive with it off most of the time.
On is great for going over speed bumps and out driveways and going over drainage dips in the road because it prevents the nose from diving into the street. No, it's not just for racing, it's a very practical tool. Not that it's really necessary, but it's fun in the canyons too.
It is lower, which is a good thing because it means your car will be at the correct ride height, slung low as it should, but not crazy low. Just right.
Look at the pics in the link in my sig below, you'll get the idea. My GTS has the P17 sport suspension option.
Are we talking about PASM, or are we talking about the Sport Suspension?
If the latter, then the ride height is 20mm lower and I believe a little stiffer than the normal PASM suspension.
Not PASM, Sports Suspension option on a GTS...
Does it actually have a button (that looks like a shock absorber) for that option or is the button for PASM? And, not to change the height of the car, to change the stiffness of the ride...
Thanks!
Steve
Thanks!
Steve
From what I have heard, PASM is adjustable but the Sports Suspension is not. Am I wrong? Are they both one and the same? Do they work in conjunction with one another?
Again, Thanks!
PASM is the handling control system. It stops the wheels from spinning and will slow the car down etc if for example you go into a curve too fast. The sport option changes the suspension settings through the use of adjustable shocks and the throttle response. It has two buttons so you can only activate the sport option for the suspension if you want. However I fail to notice any difference when The sport suspension option is on. No matter what setting you choose the car is kidney jarring stiff. Don't expect any comfort going over potholes or expansion joints. I bought my 997.1 used so not sure if these were options or not. I have one PASM button and two sport buttons, one with a shock picture on it and the other stating sport.
Sorry, this is incorrect.
PSM ( Porsche stability management) is the traction control system responsible for limiting wheel spin and controlling traction through the use of abs.
PASM ( Porsche active suspension management) is the computer controlled suspension that adapts to road conditions and increases or decreases stiff damper rates in corners.
PASM comes with regular and sport mode. In sport mode, little flaps engage inside the shock towers to redirect hydraulic fluid to stiffen the shocks.
Sport suspension, is a slightly modified version of the overall suspension, via springs to lower the car. I believe it's also the euro spec. I thought it was 20mm but someone else mentioned 10mm lower.
The car does not lower or raise its ride height with the push of a button.
A GTS with Sports PASM has a lower ride height than just PASM and also comes with a rear locking differential (LSD).
I did not find Sports PASM to ride rough at all
What about the 981/991 Sport Suspension? It's not sport plus; it's a completely different option that appears (via pricing) to NOT have the adjustable PASM dampers and thus no sport shock button. Near as I can tell, it's 10mm lower than PASM, with stiffer springs than PASM and with stiffer dampening than PASM on stiff. But can't be disabled, so it's like running on stiffer-than-PASM-stiff all the time. But it's hard to find really good information on this stuff.
Anyone have this option or have experience with it? How's it compare to PASM in the stiffest mode? Is it a significant enough performance advantage for autocross to live with it on the road every day as a daily driver, or would I hate life and wish I'd compromised with PASM?
There is no Sports Suspension for GTS or even Carrera S! There is PASM and Sports PASM.
And to the OP...the whole thing IS very confusing until you get a car and start messing with a bit, then it will make perfect sense on how everything works. Porsche confuses the $hit out of things with their acronyms and other naming...PSM and PASM for instance...they sound like the same thing and as you've read they have NOTHING to do with one another. At any rate...YES make sure you get a car with Sport mode...you'll love it and appreciate it!
