Is the burp valve on the coolant reservoir supposed to rise on it's own when the engine is at operating temp? Mine always does and I don't know if it is supposed to. It drops back down again when the car is cold.
+1 Normal for 997 but not for the 996/986 cars. System could be burbed when hot by raising the valve. I questioned whether or not my valve was working correctly after I got my 997 because of the way it worked in the Boxster. As it looks like the very same valve I figured they worked the same way.
interesting. FWIW, the only 996 i've been close to was a '01 turbo with overheating issues at a DE. his burp valve worked the same as mine - open when hot, closed when cool. oh well.
