Spacers...wobble...
#62
myw and wheeler
Here's a link to a better set of photos of the wheels
https://rennlist.com/forums/997-foru...n-the-gts.html
#63
This is why you measure twice, and cut once.
(And my first response was a real answer to his problem. Ditch the spacers = problem solved)
I am sorry if I have hurt some feelings. Telling people they are not as smart or as good a driver as a Honda driving ricer must have hit a little too close to home for some folks. And for that, I am truly sorry.
You'll love it there. A small group of people dedicated full time to creating arguments and hurling insults.
#64
Have you considered becoming a paying member so you can access the politics and controversy forum? https://rennlist.com/forums/politics...ntroversy-212/
Well, that and a giant shopping mall according to my wife. (who, BTW, responds to more post here than I do. I was gone all weekend)
#65
LOL
#67
I still plan on getting H&R spacers once I get back stateside. I asked specifically about them on here, everybody raved about them.
And i'm doing it because it looks cool, who doesn't like a nice wide stance?
#68
I though all spacers were like that, you first put the spacer on the hub using flush allen bolts and then use your original bolts to attach the wheel onto the spacers.
My 993 had spacers like that, I would not put spacers that are lose with longer bolts, I could see where wobble would come into play this way, bad torquing of lugs.
And I agree that spacers are for looks only, but it does look good!
I'm not sure it is strictly for looks. Is it possible the Porsche rear wheels may rub on the inside without the spacers? Never tried the Porsche rims without spacers (the winter set is much narrower) but since Porsche built/shipped the car this way I figure they did it for a reason. Or, since I have a low volume optional rim (Carrera Sports) Porsche may just make one offset that fits both NB and WB cars and uses the spacers for the WB?
Regardless, I don't think there are any strength or engineering concerns - at least not with my setup. A 99 Honda Civic with the wheels sitting 3 inches outside the fender is an entirely different situation and an apple to oranges comparison.
#69
Both work but I agree the Porsche spacers seem to be a better solution. The 2nd set fits the center of the hub on the 3 tabs w/ no slop and have a "duplicate" set of hub tabs for the wheel. No issues. Without the duplicate tabs - just a donut w/ 5 holes - I agree it would be an issue. (Porsche spacer has the tabs also.)
#70
Dumb question, can you glue the spacer to the wheel or the hub with silicone (which is easy to take out is necessary), so it is perfectly centered and then put the wheel on the car? If the problem is the spacer not being 100% centered would that not be a solution? The amount of silicone would be minimal. I think it is worth a shot.
