997 C4s Brake upgrade???
Hi Guys,
Does any of You have experience with Brake Upgrade on a 997 C4s 2008, I was thinking about Pfc. Etc maybe larger discs on the front.
I hope somebody can help Please.
Thanks a lot
Best regards,
Sune.
Thanks a lot
Best regards,
Sune.
If you don't track the car a lot it's a waste of money. But you can upgrade to gt3 6 pot calipers...bolt right on and 350mm Turbo (they are correct offset) rotors for the front. Do the same in the rear and you will have the same brakes the Carrera's in Grand Am GT run.
What's wrong with your brakes anyways? My OEM brake and pads worked pretty good until I got quite a bit faster, and then just use Ferodo 2500 pads for summer/track and OEM pads for winter.
This:
I thought you might be interested in reading this web page:
https://rennlist.com/forums/showthre...ferrerid=93376
From,
TJ Elliott
From,
TJ Elliott
This:
From,
TJ Elliott
From,
TJ Elliott
1- install GT3 uprights
OR
2- install,some sort of bracket to change the mount point of the caliper
The best way is to change the uprights.
OP has never stated WHY he may need the upgrade?
Hi Guys thanks a lot for The inputs. I do apriziate it. Yes the brakes a good on C4s but can always get better. It is a mot I will do for a Friend after he had a Passanger ride in My Gt3 Cs withv Pfc 380 mm on the front and 350 mm on the rear.
And Yes it is for the Track.
Had anyone Tryed any Pfc upgrades on a C2 or C4s???
