A twist on the Gundo mod
Old 08-26-2014, 01:21 PM
  #46
vern1
vern1's Avatar
Originally Posted by BReif61
Isn't this just what the PSE does, without the insane cost and fancy solenoid?
No. The PSE takes that tube and directly vents it to the exhaust ie similar to the gundo so this is nothing like PSE
If you want PSE sound go gundo (and yes, way way cheaper than retrofitting PSE)
Old 08-26-2014, 02:18 PM
  #47
toptier
toptier's Avatar
Really? Every picture I've seen of OEM PSE mufflers shows otherwise. I do not see anywhere that the inlet before the muffler gets vented to the exit pipe. Which the Gundo hack does.
Old 08-26-2014, 02:29 PM
  #48
vern1
vern1's Avatar
same effect ie pse vents directly to the tips. gundo goes from inlet pipe to outlet pipe to tips
point was that it is not the same as what the hack in this thread shows ie inlet to inlet and cant see how that effects the sound
Old 08-26-2014, 03:14 PM
  #49
PhilD
PhilD's Avatar
I believe it allows some of the inlet to bypass some of the chambers in the muffler, thus creating a louder sound.
Old 06-09-2017, 07:46 PM
  #50
pitargue
pitargue's Avatar
Bringing up this thread from the past.
The original youtube video is gone. Was this the original video?
Old 06-10-2017, 01:48 PM
  #51
Britjunkie
Britjunkie's Avatar
I bought these from Hank and had a local shop weld them up. Car is a 997.1 and the sound is awsome. Not obnoxious puttering around town, but really howls when you get on it. I couldn't be happier!!
Old 09-28-2019, 09:09 AM
  #52
Chris M.
Chris M.'s Avatar
https://youtu.be/QqBXiZUczPw
Can’t be the original video because that is a 997.1. OP’s car is a 997.2.
Old 09-28-2019, 07:29 PM
  #53
Hi-Arc
Hi-Arc's Avatar
Interesting Exhaust mod. My try this with an extra set of muffler I have. Thanks for posting
Old 09-29-2019, 01:10 PM
  #54
RDIMA
RDIMA's Avatar
Was video removed
Old 10-01-2019, 09:38 AM
  #55
Chris M.
Chris M.'s Avatar
These are .2 mufflers so the inlet and outlet are the opposite of .1 mufflers. The middle pipe is the inlet. The newly created pipe taps what is normally the outlet on a stock .2 PSE muffler and turns it into an inlet. The gases enter the muffler through both the middle and upper tubes (as the mufflers are installed on the car), go wherever they go inside based on the baffles, and exit through the only exit which is the lowest tube. I have to assume there is less baffling in the third (newly tapped) chamber since this is what the PSE gases go through. Stock PSE has two outlets, this mod has two inlets. Like this:
Old 02-07-2020, 12:17 PM
  #56
Rusty Heap
Rusty Heap's Avatar
Bumping Thread.
Any new Comments, pro's or cons?
my app is a 996 C4S
I have an extra set of mufllers off of craigslist so I can always go back to stock.
Old 02-07-2020, 12:34 PM
  #57
Christian Stark
Christian Stark's Avatar
There are a lot of issues and moving parts here.
On a 997.1 this would provide 1 entry in to the muffler, and 2 out. I THINK both outs are muffled however.
On a 997.2 this would provide 2 entry into the muffler, and 1 out. Both entry pipes are muffled on a stock 997.2 muffler however.
The mufflers on a stock 997.2 look like the PSE mufflers on a 997.2, but the internals ARE different.
Gundo type hack truly bypasses the side cans for a % of exhaust gasses on a 997.2. The Hanksville does not.
I am fairly certain any change to flow will change the note, so I am not arguing that the Hanksville on a 997.2 is no different to stock...I am merely arguing it is different in flow to a Gundo.
You have a 996, which may or may not be different than a 997.1 or a 997.2 So I really don't know...I hope someone will here, but you may want to post this in the 996 forum as well.
Originally Posted by Rusty Heap
Bumping Thread.
my app is a 996 C4S
Old 08-09-2021, 09:55 AM
  #58
BmacIL
BmacIL's Avatar
What you have there for IN and OUT are reversed. Red is in. Green is out.
Edit: sorry, 7.2 flipped this vs 7.1
Quick Reply: A twist on the Gundo mod
