Lowering Springs w/ Stock Shocks
Has anyone tracked a car installed with lowering springs (I have the Techarts) combined with the stock shocks? I'm wondering as I would like to use my car on the track but am not sure if my suspension setup is sufficient.
usual lowering springs have almost same stiffness compared to stock springs so you not going to feel much difference.
to improve track performance if you do not want to replace much of suspension you can install gt3 sway bars, that will reduce amount of tilt in the corner and will improve car a bit, then search here on all the advices for suspension setup.
