The last few days I've that sometimes my window is not suctioning like it does when you shut the door? What causes this, is something on the way out?
It's called indexing...it probably just forgot so you have to reset. Run your windows all the way up then hold the switch in the up position for a second or two. The procedure is in the owner's manual in the battery disconnect area.
