Sport Exhaust Issue
Old Jul 8, 2013 | 12:48 PM
Vampire's Avatar
Vampire
Default Sport Exhaust Issue
I have a ’06 997 (45K miles) with factory sport exhaust that is permanently on by disconnecting the connector. I have a raspy/vibration like sound sometimes when lightly accelerating around 1500 RPM. It seems to be worse when the engine is cold.
I am not sure if it is coming from within the exhaust (my guess) or is an external rattle. I thought it was always there, but lately it has gotten much louder.
I will try taking it out of sport mode for diagnosis, but wondered if anyone else has anyone else experienced this?
Old Jul 9, 2013 | 01:07 AM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
Yes. Common problem. What you are experiencing is the dreaded fractured band issue with the PSE. Routinely, if driven enough when the car is under warranty, Porsche will pick up the tab. However, with so few miles on it, the problem didn't manifest itself until years later. (And you thought buying a low miles car was a good deal!)
See post 13 in this link:
https://rennlist.com/forums/997-foru...n-exhaust.html
Old Jul 9, 2013 | 01:27 AM
Renzsport's Avatar
Renzsport
Had this happen to mine as well. Got the brackets all welded up and strengthened, now all you hear is sweet music!
Old Jul 9, 2013 | 11:51 AM
SecretAsianMan's Avatar
SecretAsianMan
Same here. My local shop removed the mufflers, welded up the brackets and reinstalled for not much $. 100% fixed.
Old Aug 27, 2013 | 01:52 PM
Vampire's Avatar
Vampire
i just found out I have two issues.
1. The bracket was broke and welded back
2. Baffle inside one muffler is toast.
Old Aug 28, 2013 | 11:55 AM
MagnusB's Avatar
MagnusB
Vampire, how do you know the baffle in the muffler is toast?
Old Aug 28, 2013 | 12:28 PM
Vampire's Avatar
Vampire
My mechanic, whom I trust, told me it was toast. He would try to fix it if he thought he could.
He did fix a broken weld on the mounting bracket and that did not help.
The car sometimes makes a loud raspy sound under light acceleration in the 2000- 2500 RPM range and it is worse when the car is not warmed up. I can hear that it is coming out of one side and not the other.
I have my PSE turned on by default and cannot turn them off until I reconnect the wires. I will do that tonight an see if that makes a difference, but I like the note of the PSE in loud mode.
I have the original system at home, but was wondering what other systems people like? Fabspeed?
I don't need power improvements as I don't track this car.
Old Aug 28, 2013 | 11:52 PM
fastm3's Avatar
fastm3
If you decide that you want to go the Fister route, PM me. As you may know, they apparently sound practically identical to the PSE in sport mode. I've got an almost new Fister 997.1 exhaust system that I'll be listing in a couple of days.
