Avg oil & engine temp 997.1
My oil consistently reads about 210-220 and I have the center radiator. It's been 98-100 degrees and 100% humid here this time of year so I don't worry about it.
Wow you must rarely drive your car, otherwise that would be a PITA.
And when you say normal driving (which means not going beyond about 4000 RPM).....
.... I don't rag my car out by ANY means at all, but I take it up to 5-6k all the time without even thinking about it. If I'm trying to go fast then maybe I'll let her get to 7k and that's rare but how in the world can you stay under 4k??!
I keep a log of my oil and water temps on every drive. Outside temperatures generally range somewhere about 70-90F during most of these drives. Humidity level are really low...like 15%.
Normal driving (which means not going beyond about 4000 RPM)
Oil : 190-200F
Water: 175 F
Spirited driving:
Oil : 210-215 F max
Water: 175F
I do have a low temp thermostat.
--Von
Oil : 190-200F
Water: 175 F
Spirited driving:
Oil : 210-215 F max
Water: 175F
--Von
Robocop305 (05-04-2021)
.... I don't rag my car out by ANY means at all, but I take it up to 5-6k all the time without even thinking about it. If I'm trying to go fast then maybe I'll let her get to 7k and that's rare but how in the world can you stay under 4k??!![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
Specially with a 911!
[QUOTE=Luxter;11538355]Why?
Its my understanding that for the best acceleration the shift point should be determined by finding the RPM that gets the car on the high point of the torque curve when going to the next higher gear. When I ran the numbers for my Carrera S they fell into the 6950 - 7000 RPM range.
Can you elaborate for us clueless members?...Thanks
