TPMS Question
Old May 30, 2013 | 07:05 AM
911meister's Avatar
911meister
Default TPMS Question
I have verified that the tire pressures are correct and in fact are very close to what the monitoring system say. I constantly get an add air comment on one rear tire. If I do the learning it learns and is fine (pressures reading correctly) but as soon as I turn the ignition off the error comes up again. Any comments? Thanks.
Old May 30, 2013 | 08:42 AM
jhbrennan's Avatar
jhbrennan
How old is the car? Could be that the sensor battery is on its way out. Dealer can use PIWIS to check battery level.
Old May 30, 2013 | 09:21 AM
911meister's Avatar
911meister
Ah, OK. Thanks. Car is 2007.
Old May 30, 2013 | 11:55 AM
USMC_DS1's Avatar
USMC_DS1
I have an '08 C2S. Two TPMS sensors replaced - one last year and one this year. You may be due for some new sensors but follow what JH indicated.
Old May 30, 2013 | 04:41 PM
GR997S's Avatar
GR997S
My is a 2006 and just replaced all 4. I think you are due, as mine started to act as yours before I replaced..............GR
