Intermittent start issues
Hi guys,
Two issues I need help with:
1. I'm trying to troubleshoot what appears to be a new intermittent electrical gremlin. Typically prior to turning the key to ignition, I turn just to the point where the electrical systems turn on and I can get a reading on oil level. However, I have recently encountered an intermittent problem where the electrical system doesn't engage and the car won't start. They system recognizes the key (i.e.; KEY 1 or KEY 2) so I know the car can "see" the key if you know what I mean.
I thought it might be the battery in the key fob but the doors always lock / unlock without issue using the fob so I've ruled that out as the source.
I usually turn the key off, remove it, reinsert, sometimes have to repeat, then everything returns to normal and I can start the car.
It's happening every few days. It's not the battery - I replaced it last month. Anyone experience this?
2. My rain sensor died and my local indy wants $700 to fix it. huh?
I don't really use the sensor so was hoping to defeat the annoying error message that keeps popping up after I start the car? Any ideas?
Any help is appreciated.
Cheers,
Dave
Cheers,
Dave
Hi guys,
Cheers,
Dave
Cheers,
Dave
Can't help on the rain sensor.
Hi guys,
Cheers,
Dave
Cheers,
Dave
My 07 does that to me sometimes, I just turn the key left again then back to the right and it starts right up? I don't worry about it.
Your rain sensor is located on your windshield (your sensor) maybe that's the culprit?
This might seem obvious, but is your battery in good condition? A while back I was having various electrical gremlins, power windows were getting weird, etc. Turned out my battery was starting to go bad.
Installed a new one and all is good now.
Your issue sounds more complex. I've had similar issues, but mainly with hot restarts. Already replaced Alternator/Starter cable, replaced battery with higher CCA, and had fuel pumps checked (OK). Needs to have a comprehensive check
A cab does tend to sit around a lot, especially in Canada, eh? So I would definitely get the battery checked-out or just replaced if there's any doubt. That's the cheapest repair available.
As for the rain sensor, that should be a pretty generic Bosch part that BMW and Audi and everyone else uses. It's just stuck onto the windshield and should be easily replaceable. $700 seems excessive. Maybe the shop doesn't know any better and wants to replace the entire windshield?
Thanks for the feedback guys. I've got a brand new battery so I doubt that's the source of the intermittent starting issues. The rain sensor likely got damaged when I had the windshield replace before putting the car away for the winter. I'll check into the part cost and maybe replace this myself.
