Car won't start--jumpstart question
Cruisin'
thanks!!! This worked great!! Thanks for the advice QUOTE=jennifer911;14216065]Saibaji, in the little storage tray, directly in front of the shift lever, use a small blade or screwdriver to lift and peel back the rubber mat. You will see a round hole, look down it and note the round pin. Using a small screwdriver or other implement push the pin downward. This will release the shifter lock allowing you to shift into neutral.[/QUOTE]
