Lug nut tool
So I bought some wheel spacers and when attempting to put them on realized that my locking lug tool was missing. So the last set of tires I had put on at Americas tire they obviously forgot to return the tool to car! Decided to check my wife's Audi Q7 to see if hers would fit and guess what hers is also missing and where do you think her tires were replaced, Americas Tire!
If you were mounting spacers you should be using new, longer lug bolts so it doesn't matter if your old key is missing - you need a new set of bolts anyway...but then I guess you need the key to get the old one's off - bummer. Some dealers (or even America's Tires) may have a master.
Unfortunately, as a car owner, you have to stay on top of this yourself. No one else cares as much as you do about your wheels and car so you have to always check before you put any distance between you and your tire shop. (I also keep several spares to my key--the one in the car stays with the car permanently, while I have several in my tool bench.
Watch the "technicians" when they torque your wheels....the torque wrench clicks and they crank it another 90-180 degrees. They apparently do not grasp the concept at all. Now I torque my own.
Not to ask the obvious question, but, are you sure the key isn't in the car. The fact that both your vehicles have keys missing from a shop that in general gets high marks on the board seems surprising. Those little keys are easy to store in different locations. Glove box, in tool kit bag, etc. I'd turn the car upside down. Good luck. David
I have had issues with the shop finding the key locking socket also. I have seen many posts about this, but never a post about stolen wheels. Considering getting rid of it, as a nuisance. I am not sure where that gadget is right now anyway.
I had similar locks on an SUV used to tow a boat. The locks rusted on from salt water exposure on the ramps and had to be cut off, along with the studs. Similar issues could be expected on roadways that are salted. The saving grace here is that the tires have such a short service life that the locks don't have time to rust up solid.
