Sport Chrono Pkg installed today!
I'm only guessing but I think the confusion here is GEO356 has a 6 speed and Zucc has a PDK. 6 speed = one button. PDK = 2 buttons, launch control etc.
Again, I wouldn't own a PDK without Sport Chrono..Sport mode or whatever it's called. I think you are both correct but trying to compare this function between a manual car and a PDK.
If you have a 997.2 with PDK and order the correct upgrade package from Porsche, you will receive the Sport and Sport Plus buttons and program disk. The dealer has to install this and get it activated by Porsche in Germany. I believe the dash panel with the 2 extra holes is a separate part? The kit for the manual trannie will come with one Sport button.
I have a '12 997.2S with PDK and had this program added to my car after purchase. I did not however, get the lighting and other...if there are other....PCM controls. I do not have PSE, so I did not get that obviously. I have asked two different dealers about the lighting controls. The installing dealer said.."you don't have that" and the second dealer upon trying to reprogram the PCM created such a mess that the car was out of service for about a month while they "repaired" or re downloaded or tried to explain to Porsche what had happened.... I do not know if I have launch control, since I haven't tried that function. I do however like the sport and sport plus modes and am glad I had the car upgraded.
Yes, USMM, if I was doing it again, I would check things out a bit more. I thought of it as a fairly simple program upgrade and did not ask enough questions. My situation is somewhat unique on this forum in that I am in rural NC about 2 hours from any dealer and it becomes a hassle to drive back and forth for small problems. The folks who tried to reprogram it actually worked pretty diligently, but in the process the car or the programmer....? burned a module or some switch that had to be replaced with the part coming from Germany. Literally. I have other cars, and it was winter time, so it was only a hassle that the car was not at home and nothing more.
During the process, I chose to leave the car with the dealer until it was repaired fully. The car was otherwise drivable, it was just that the Sport mode was turned off inadvertently, in the first attempt to turn on some of the other controls. later during the return trip for the repair for which the car was flat bedded to the dealer, at the dealer's expense. During the second attempt to turn the Sport and Sport Plus back on the module or switch problem showed up. It truly did take most of a month to get it sorted out though. The whole thing makes for a good story that I tell when people ask me what kind of service the car has given.
After reading this thread I thought about checking with the folks in Cary as that is not much farther for me than the dealerships I have used already.
Best of luck. Let us know how it goes.
Thank you very much for your input. That's why I love Rennlist. With out exaggeration, Rennlist has saved me at least $2000 with DIY posts. I am constantly learning more about the cars I own which helps me make better decisions going forward.
After I had mine installed last year, one of the first things I did was test the sport button, sports plus button and launch control. I just wanted to make sure that every thing worked as advertised. Everything worked perfectly but honestly I never bothered to play with light controls or the other PCM functions. I assume they were already set to my liking. Anyway, I highly recommend Leith in Cary, NC if you want to add this feature.
Here is a question. I am picking up a 06 997 this week and it has the Sport Chrono Package. However, I thought the Chrono package automatically came with a different steering wheel. This car has the standard steering wheel and I have always seen the Chrono package with the steering wheel that has the round horn/center airbag? Any thoughts or clarification? Thanks
Newbies Hospitality Director
Hi there, i'm a newbie, first post...so..I ordered my 2015 991 I need advise on the SC Package. Don't like the clock on the dash, but, I'm told the addition of the engine mount sensors is worth it. True? It's a manual trans so all the other SC electronics, like launch control, don't apply here. Thanks
