997 Best Rear Brake Ducts
Can anyone let me know what brake ducts they are using on their 997s? i ordered the gt3 front they were around $20 for the pair
i was unable to find a gt3 rear brake duct part # did they not come with them?
i found 997 turbo ones -
http://www.ecstuning.com/Search/ES25...881/ES2581880/
i know the ultimiate option is the cup ducts.. but thats just overkill for me and very expensive.
as a point of reference i just switched to endless rf650 fluid and ss brake lines.. going to flush and install the lines with weekend
Thanks, mike
Thanks, mike
I also fit Turbo rear brake ducts to my 997S. Cheap as chips and a simple install once you figure out where they actually go.
NOTE: if you have 11.5" rims on a narrow body car you will need to trim the duct a bit as it ever so slightly rubs the rear wheel. If you have a wide body, narrower rear wheel, or spacers it likely wouldn't be an issue. Trimming was easy enough to do but something I didn't realize until I had refit the wheel and saw how close the tolerance was.
Link ? Please?
Just call in advance and have your local dealer order the parts for you. I can't imagine them being cheaper online, in fact most places I've seen advertise them for MORE than the dealer.
GT3 front ducts: 997-341-483-92 & 997-341-484-92 ($4.97/each)
997 Turbo rear ducts: 997-331-487-02 & 997-331-488-02 ($21.15/each)
$50 and an hour of your time to install all four. Makes for an easy and satisfying DIY.
Former Vendor
