997.2 oil change
997.2 oil change
Getting ready to do my first one - Do I need a filter wrench? If so, what size? I see them listed for the 1.s at suncoast, but not .2
All the DIYs are also for .1s, so...
36 mm socket for the oil filter housing. Other steps are discussed here and the linked threads. Hope this helps.
https://rennlist.com/forums/997-foru...7.2+oil+change
I'd also check if you even need the 36mm socket. This is what was listed on the DIY for .2 oil change on 6Speedonline. It confused the hell out of me as my filter housing just has a screw off cap (with a large plastic nut). Changing the oil on these is really easy, most of the time consumed is waiting for it all to drain out.
Don't forget to replace the crush ring when you put the drain plug back in!
Bottom line: oil change on 997.2 is extremely easy.
HAZET makes a nice 36mm 3/8 drive socket especially for the filter housing. 3/8 is best drive so that you can use a properly sized 3/8 drive torque wrench. The Hazet is also a very low profiloe socket which is also helpful.
+2 - ready to replace if needed. The oil drain plug as noted is easily deformed so having a replacement handy makes life better - with any slight indication of burring, I'd replace it. Crush ring is also cheap so have spares available too. Some folks have flipped it over and re-used, but it is a minial expense. Follow torque specs as best as you can; test refill oil level before you add the last quart to ensure you have not overfilled, then slowly top off to proper fill line. You may want to wait a day and drive a bit and check again before final topping off (this will also allow you time to check for any leaks).
