Airbag light 2006 997.1
#46
Got the 805A code today. Is there a narrative or instructions anywhere, should the problem being the sensors, on how to remove the front bumper?
#49
Revisiting this, had a “passenger” airbag warning light, replaced the sensors and now has an airbag warning.
don’t have anything to reset however I heard that if I disconnect the battery, it may do the trick? Anyone have experience with this?
#50
Airbag warnings font usually clear with a battery disconnect / reconnect and usually require a scanner.
#51
Hi Guys,
I got error code 805A - “Passenger’s front sensor, no communication” on my 2006 997.1 Base.
Based on all these threads I suppose I’m going to purchase a New Acceleration Sensor Front for about $165.
Seems I need to remove front bumper but some say you can get at this by removing front indicator/fog light. I removed this and didn’t see how the sensor was accessible. Anyone have luck doing this?
Any other suggestions?
Hope this works,
Thanjs
Hope this works,
Thanjs
#52
Having the same issue. What's the part #? How do I know which sensor to replace?
#53
[QUOTE=2006 997.1;18747072]Hi Guys,
Hope this works,
Thanjs
Hope this works,
Thanjs
#56
For anyone who has the front sensors in the front bumper go bad. You don’t need to remove the whole bumper to replace. Pull out the turn signal/fog lights and your have good access. Takes 10mins to R/R the sensors this way
Durametric Fault: Airbag - POSIP
Current Fault Codes 805A: Passenger's front sensor no communication
#58
I have pictures of the sensor and their mounting screws but they are on a saved word file so I cannot post them. If you want the pics send me your email address and I'll email you file..
The following 2 users liked this post by 1940Woodie:
911URGE (07-28-2023),
IrishLegend (07-27-2023)
#59
So do I need:
997-618-221-01
or
997-618-223-02
997-618-221-01
or
997-618-223-02
#60
