LT Fuel Trim 3% higher on one side = normal?
Using an OBD reader while driving, my long term fuel trim is consistently 3% higher in Bank0 compared to Bank1. It doesn't matter if I'm idling or on the highway. The absolute values are usually near +3% in Bank0 and 0% in Bank1.
Normal variation or bad?
This is a 997.2 S.
This is a 997.2 S.
Plus or minus 10% is the acceptable range for fuel trims. Brand new cars should be plus/minus 5%. So you are w/i the acceptable range. For an accurate value you should add short and long term together, as they effect each other, and see if they fall w/i those ranges. Positive fuel trim means you are running lean (adding fuel ) and negative is rich (subtracting fuel).
