Help. Light issues.
Old Feb 8, 2013 | 02:16 PM
Chaos's Avatar
Chaos
Default Help. Light issues.
Had the door handle mechanism replaced and while the car was being bieng adjusted re window drop,the tech ask me if I wanted the DRLs turned off. I said yes and now when I start the car with the light switch off,headlights,markers and tail lights come on. The older and newer computers will not reset the lights.
Techs say this has never happened before. The turn DRLs on or off for Canadian cars.
Thanks.
Old Feb 8, 2013 | 03:46 PM
jhbrennan's Avatar
jhbrennan
Thanks.
Doesn't look like they turned DRL's off. If you have Sports Chrono you can do it yourself using PCM - from the Main button select Set and you should see Individual Settings of which DRL is one. Car has to be stationary when you cycle on/off. I believe that PCM functionality doesn't exist in Canadian cars since DRL are required unless it was a US car sold into Canada...so what's your question??
Old Feb 8, 2013 | 04:41 PM
Chaos's Avatar
Chaos
Every time I start the car, head,tail,marker lights come on when the light switch is off. Dealer cannot turn it off.
Old Feb 8, 2013 | 05:13 PM
jhbrennan's Avatar
jhbrennan
I have DRL activated on my 2008 TT and all my lights are on except the instrument panel. When I turn DRL off using PCM, they are all turned off. If you have Sport Chrono have you tried turning DRL off?
Old Feb 8, 2013 | 11:31 PM
Chaos's Avatar
Chaos
Have sport chrono,tried using the stalk,no luck. It started when the dealer tried to turn them off with his computer.
Old Feb 9, 2013 | 08:54 AM
jhbrennan's Avatar
jhbrennan
The stalk won't help you. Select Main on the PCM then select Set and you should see an Individual Settings menu...then make your choices. You never touch the stalk. Come on man, get this fixed.
Old Feb 9, 2013 | 01:51 PM
Chaos's Avatar
Chaos
T H A N K Y O U !!!
My dealer had NO clue,neither did I
Old Feb 9, 2013 | 02:54 PM
jhbrennan's Avatar
jhbrennan
T H A N K Y O U !!!
This question gets asked often so you're not alone...but I'd look for a new dealer.
