Swapped .1 multi function wheel to .2 GT3 RS wheel.
Old Feb 3, 2013 | 05:04 PM
AWay's Avatar
AWay
Default Swapped .1 multi function wheel to .2 GT3 RS wheel.
I didn't particularly care for the triangle airbag shaped multifunction wheel on my car and decided to swap to the newer .2 GT3 RS alcantara wheel. I figured I might as well do the shift **** to match at the same time. The swap was easy enough after some fiddling with unlatching the triangle airbag.
On a side note, I was curious about the shift linkage I found when replacing the ****. It appears to be an aftermarket short shift kit or perhaps the factory SSK? I wasn't sure and the build sheet of the car didn't mention the factory option. I was hoping someone might be able to identify it for me.
Old Feb 3, 2013 | 05:47 PM
Spokane5150's Avatar
Spokane5150
Looks great.
tooloud10's Avatar
tooloud10
Team Owner
That looks great! I'm scared to know what it cost, though.
Old Feb 3, 2013 | 06:13 PM
zer026T's Avatar
zer026T
Looks like the B&M Short Shifter Kit.. Haven't seen up close before but looks identical to the pics:
http://forums.pelicanparts.com/porsc...led-996-a.html
http://www.bumperplugs.com/BMSSdetails.html
Old Feb 3, 2013 | 06:43 PM
USMC_DS1's Avatar
USMC_DS1
+1... B&M SSK.
Old Feb 4, 2013 | 08:32 AM
AWay's Avatar
AWay
Good to know, thanks gents.
My last 997 S had the factory short shift and I thought this one felt vaguely similar.
Old Feb 4, 2013 | 02:32 PM
Dave's911's Avatar
Dave's911
Looks great, nice job. Did you need any other parts for the wheel conversion, or was it just the wheel.
I'm thinking about doing something similar, although I'd like to keep the multi function option, so would go with that wheel.
Old Feb 4, 2013 | 02:34 PM
AWay's Avatar
AWay
Thank you. No, it was just the (admittedly overpriced) wheel and airbag needed for the swap.
I of course lost the multifunction options in the process but as this is a 'fun' car they were of no great concern to me. We seldom even use the radio.
Old Feb 4, 2013 | 02:36 PM
Dave's911's Avatar
Dave's911
Thanks. Like I said, it looks great. Nice upgrade over the triangle wheel.
Old Feb 5, 2013 | 02:29 AM
fastm3's Avatar
fastm3
For some reason I thought going from a .1 wheel to a .2 wheel wasn't so straightforward....
Looks much better. Enjoy!
Old Feb 5, 2013 | 04:25 AM
IslandS52's Avatar
IslandS52
are you looking to liquidate your old shift ****/boot?
Old Feb 5, 2013 | 04:49 AM
pissedpuppy's Avatar
pissedpuppy
+1 on the wheel - fantastic. Wild appreciate more info, wasn't certain a .2 GT wheel was a simple swap onto a .1 997, great to know it is.
Where purchased, who changed it out??
Old Feb 5, 2013 | 05:56 AM
AWay's Avatar
AWay
Definitely a straightforward install. Disconnect battery, unlatch airbag, remove torx bolt from wheel (T55 I believe), replace with new wheel, plug in new airbag orange connector and push in new airbag. Done.
The hardest part by far is unlatching the airbag since you're just inserting a screw driver by feel.
I had my dealer order the parts with my PCA discount and I did the swap. After unlatching the airbag it's a 5 min job.
Old Feb 5, 2013 | 11:34 PM
amok's Avatar
amok
Any interest in getting rid of your old multifunction wheel?
Old Feb 6, 2013 | 12:24 AM
David A's Avatar
David A
Better looking and much sportier, nice.
